Signal Conditioning
strain null function
i m using a 1520 module with a 6024 DAQ acquisition card..
i'm programming under VB 6...
when i use the function SCXI_Starin_Null after making some acquisition with the cwai "tool" i obtain the 10636 error and the null don't take effect...
if i hadn't made any acuisition before it's ok but when it's done i had to rebot my computer to do the null...
is there a things i don't do right???
thanks ..
olivier
(3,440 Views)
Olivier,
The problem has to do with the fact that you have double-buffering enabled when you call SCXI_Strain_Null. This will cause the -10636 (You cannot start a continuous (double-buffered) operation with a synchronous function call) error. The solution to this problem is to disable double-buffering before calling SCXI_Strain_Null. The function DAQ_DB_Config allows you to disable and enable double-buffered mode.
Good Luck. . .
Spencer S.
(3,440 Views)
I'm having the same problem, but i can't seen to find this function DAQ_DB_Config you said. Please tell me where to find it.
(3,440 Views)
