Signal Conditioning
unable to add 2nd scxi 1000
ref request #7029972
error message "unable to test chassis at this time"
(2) 6036E as device 4 and device 5 (multiplexed mode)
(2) SCXI 1000 with scxi 1100 and scxi 1300
Encountered during System migration from Mac to windows
replaced scxi 1000 chassis same problem
LV 6.1 /Win2000
(2,934 Views)
Hi Mike,
Have you tried testing the fuses on the chassis? You might also want to try switching the modules and cables. Also switch the 6036E boards to see if the error seems to follow the board or the module or the chassis. Once we narrow down which component of the system is causing the error then you may need to send it in for repair. To continue trouble shooting or if you've determined that one part is broken you can call 1866-275-6964 and enter your service request number.
Sarah Miracle
(2,934 Views)
