Signal Conditioning
temperature values at high fixed values
I have two 1102/1302 with 6363 that has worked fine in the past.  After some down time I ran the vi and did not get correct values.  I investigated the virtual channels in MAX and the table has high fixed values for all channels (218-219 C) at room temperature and they are static values.  It would seem these values are not being read from any connected TCs.  Any idea as to what could cause this behavior?
(5,911 Views)
teslac,
How long has the system been sitting?
Make sure that the hardware is physically set up correctly. Also, make sure that the correct thermocouple type is selected on your Virtual channel.
Do you get the same values if you run the MAX Test panels?
Do you get the same values if you run the example LabVIEW Program “Thermocouple - Continuous Input”
Rob W.
(5,865 Views)
Accepted by teslac
I found the issue late yesterday and it turned out to be a hardware issue.  The problem is now resolved.
(5,852 Views)
