Signal Conditioning
thermocouple problems..
I have set up a K-type thermocouple using Measurement and Automation Explorer. When I run the test panel, everything appears fine, and I get a reasonable temperature value. However when I run Server explorer it tell me that the quality of the temperature item created is bad. This in turn means that I am unable to create a DSC Tag for the temperature reading as the value is bad. Any ideas why this might be happening?
Message 1 of 1
(3,942 Views)
