Signal Conditioning
thermocouple reading limited to a value
Have you tried to check the range specified in MAX? If you accidentally set the range for all thermocouples to 139 degrees C, then you would max out at that number no matter whether it was an open TC or a TC heated to beyond that temperature.
-Matt
Message 11 of 11
(2,737 Views)
