Signal Conditioning
wrong readings from a thermocouple
hello
Im getting wrong readings from a thermocouple T type, installed on SCXI1100/1300 using MIO6070E
Tareq
(3,141 Views)
Tareq,
first test: shortcut your TC input . Can you read the temperature of your input terminal (resp. of the tempsensor for the cold junction compensation)?
If no then you have a problem with your measurement setup.
If yes then the problem is you sensor (signal)
maybe to much noise due to ground loops or other EMC
do you use a extension cable? Right type ? Right polarity?
Greetings from Germany
Henrik
Henrik
LV since v3.1
(3,139 Views)
