Signal Generators
Can I route the internal 40MHz clock signal to any RTSI lines at the NI 5401 ?
Using the function ni-FGen Rounting Signal Out.vi can we route the internal 40 MHz clock from the board to any external connector like the RTSI lines, or the Sync output ?
(6,293 Views)
Depending on the module type, you can route a reference clock out to RTSI. On the PCI module, you can route a 20 MHz reference signal to RTSI Clock and accept one from the SMB connector, or RTSI Clock. The PXI version is designed to only accept a reference clock from the front panel, or a 10 MHz reference clock from the PXI backplane. No Exporting.
(6,293 Views)
