Signal Generators
SHC50-68 pin out
I`m using a SCH50-68 cable 184 748B-01 with a NI5401 function generator, but the pinout of the 68 pin termination is not according to the 50 pin terminal described on the NI Signal Generator help.
Please anyone help me.
Ricardo
(6,388 Views)
Ricardo,
You will be able to find the mapping from 68 to 50 pins within the following KB:
http://digital.ni.com/public.nsf/websearch/9B8A3D3DF8F1068D8625684700723D2A?OpenDocument
Once you understand the pin number mappings you should be able to apply the information found in the 5401 Manual to determine which pins you need on the 68 pin connector.
Hope this helps.
Kevin R
(6,388 Views)
