Home
Community
Discussion Forums
Additional NI Product Boards
Signal Generators
Topic
Signal Generators
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can the two pins on a 4461 measure different numbers of samples
Eagle01
Member
12-09-2009
05:11 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm using the 4461 in a cpp application. Is it possible to setup the two measure pins on the board to make a different amount of measurements.
0
Kudos
Message
1
of 1
(5,933 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
