Signal Generators
Current step inputs!
Dear All
I am trying to set current for my programmable power supply .  The set current should be varied from 0.1,0.2,0.3,......1.0A with interval of 2minutes.How can I generate the input signal for the set of currents.
Regards
bstar
(5,692 Views)
What does this have to do with NI Signal Generators? You should post similar questions to the instrument control board.
You can use the Ramp Pattern function to create the array.
(5,689 Views)
