Signal Generators
How to generate a sine wave on NI USB 6008 DAQ.
I am having trouble generating a sine wave on my NI USB DAQ 6008. Any one else having the same trouble. I want to generate sinewave to my system. Any help?
i get this error
Error -200077 occurred at DAQ Assistant
Possible Reason(s):
Requested value is not a supported value for this property.
Property: SampTimingType
You Have Requested: Sample Clock
You Can Select: On Demand
Erick Pastor
(6,178 Views)
Just like the message says, you cannot use a hardware timed output. You only have softeare timed as the specs mention. Any analog output will be limited to about 150 hz (again as the specs mention) when you write one point at a time.
(6,166 Views)
