‎02-03-2019 10:19 AM
HI.
I have Labview 2016. I set up new drivers Jan.2019. And when I launched RFSG soft panel I have an error:Error.png
What I must do to launch panel? Thanks.
‎02-04-2019 04:24 PM
Hi Valentin87,
This is usually a result of your firewall blocking the application. Can you verify that LabVIEW and the RFSG Soft Front Panel are not blocked by your security software?
‎02-05-2019 09:41 AM
No, firewall is not block.
‎02-06-2019 03:29 PM
Do you get this error when opening any of the other soft front panels or is just this one?
‎02-06-2019 11:51 PM
This error only in RFSG panel.
‎02-08-2019
11:25 AM
- last edited on
‎01-12-2026
01:00 PM
by
Content Cleaner
If it's only affecting the NI RFSG soft front panel, trying to reinstall just NI-RFSG is a good next step. Also, in LabVIEW check the Machine Access settings for the VI driver to see if it's allowing all IP addresses (https://www.ni.com/docs/en-US/bundle/labview/page/setting-machine-access-for-the-vi-server.html).
‎02-08-2019 02:08 PM
As a troubleshooting step, can you try launching the NI-RFSG Soft Front Panel as Administrator?
I.e., click Start, find the Soft Front Panel, right click and Run as Administrator.
