Signal Generators
Example for AWG in streaming mode?
Hello all,
Does anyone have some example code for using an Arbitrary Waveform Generator in what i believe is "streaming" mode?
Basically, I am trying to do the following:
1) Generate a new block of samples in Labview
2) Write them to the hardware
3) Repeat from step 1...
*However*,   physically I want the first sample of each block to be on the wire immediately after the last sample of the previous block... In other words, I don't want any delay or idle time between the blocks....    I realize real-time issues are relevant here, but that's already been taken care of....  I just don't know how to setup the hardware...  When I installed Labview & the drivers, I got a nice set of examples for NI-SCOPE,  but no *Labview* examples for NI-FGEN.   I haven't been able to find any discussions of this on the NI website,  hence this posting...
I'd appreciate any assistance anyone can offer..
-Alex
Message 1 of 8
(10,746 Views)
Hi Alex,
If you included support for LabVIEW when you installed the NI-FGEN drivers, examples should have been included and installed.  They would be found in the NI Example Finder under Hardware Input and Output>>Modular Instruments>>NI-FGEN>>Arbitrary Waveform Generation.  There is an example in this directory that will probably work in getting you started in your application, and it is named niFgen_Arb_Waveform_Streaming_Example.vi.  If these examples are not present in your installation of LabVIEW, I would recommend modifying the installation of the NI-FGEN drivers and choosing to install LabVIEW support.  Let us know if you run into any problems.
Andrew W
Message 2 of 8
(10,724 Views)
I have to pass a waveform from Labview to AWG420 and I don't know own how I do it....Do anybody know how do it????
Message 3 of 8
(9,996 Views)
I tried to pass with waveform with this command: MAGIC 1000<CR><LF>#<Num_digit><Data(1)><Data(2)>.......Data(n) [ClOCK<Clock><CR><LF>]
but I can not do it.....
Message 4 of 8
(9,995 Views)
Hi Vici,
Are you trying to use Gpib or Rj-45 to communicate with your device? There does not appear to be an instrument driver for this device. Can you post the vis you are using? I’m a bit unclear as to what you meant in your post.
Matt
Matt
Message 5 of 8
(9,964 Views)
Can you give me any example of how use this AWG command: MMEMory: DATA <file_name>,<data> for sending a waveform from LAbview to AWG. What kind are array elements???
Message 6 of 8
(9,942 Views)
The AWG420 progrmmer's manual states that the <data> field should be specified in "488.2 block format". It is not very clear what this means, but I found this site that states:
 The BASIC program will send the following data
:MMEMory:DATA ’amiqsico.wv’, #3140 <binary data>
#             The ASCII character # initiates binary block transfer
3             Number of digits of subsequent length information in ASCII
140           Length in ASCII of binary data record bytes
<binary data> 140 bytes of curve form
So, a valid string may be:
"MMEMory:DATA 'waveOne.wv', #15 0001020304"
Unfortunately, I have not had experience with this device, so this is an educated guess  :smileyhappy:
As far as sending this from LabVIEW, check out Instrument Control in LabVIEW or one of the many articles on GPIB instrument control.
Message Edited by pflores on 06-19-2009 04:26 PM
Message Edited by pflores on 06-19-2009 04:28 PM
Peter Flores
Message 7 of 8
(9,926 Views)
Also, since they share the same programming manual, you should be able to use most of the functions in the Tek AWG500 series drivers found at ni.com/idnet.
Peter Flores
Message 8 of 8
(9,925 Views)
