Signal Generators
Generate random burst w/ Labview
I need to generate a random burst that will be used as a trigger for my camera.  That is I need to capture a number of images (say 1000) with “complete” randomness.  Can I do this w/ labview?
(6,480 Views)
This can be done but will depend on how you want to set up your random functionality. For example, you could use a random number generator with a threshold to control a case structure. Whenever the random number is above a certain value, it would trigger the camera to snap images. So, yes this is very possible, but would depend on your requirements and definition of random.
-Zach
(6,464 Views)
