Signal Generators
Generation of pulse by using NI-PXI-5421 FGen
Hello Sir/Madam,
Question:
We are using the Funktiongenerator NI-PXI-5421 and simply want to generate a pulse, as it can be done by almost every cheap Funktiongenerator.
Unfortunately, I can't find a way to tell the Funktiongenerator to generate a pulse. I can generate Singals as I like but don't know how to generate a single pulse.
Do you maybe have a program which gives me this possibility?
Thank you for your support.
Message Edited by Support on 01-12-2009 09:14 AM
(7,735 Views)
Accepted by Jens.brutscher
Hi Jens,
you could try to use scripting of the 5421 board. The following LabVIEW examples:"Fgen Arb Script.vi" or "Fgen Switch Between Waveforms.vi" use scripting to generate waveforms, you could create similarly a script that generates a single DC high level pulse.
I hope this information helps you.
Blase
(7,705 Views)
You might also want to ask the moderator (Options>Report to Moderator) to edit your post to remove your serial number. It may already be too late but why should you let the entire world use your serial number to authorize their LabVIEW? Never, ever publish a LabVIEW serial number in a public forum!
Message Edited by Dennis Knutson on 11-25-2008 08:08 AM
(7,686 Views)
