Signal Generators
How to generate Random Noise with PSD profile
Hi
Would anyone be able to help me? i am trying to produce a random noise generator that outputs a signal that conforms to a predefined PSD profile.
cheers
(10,509 Views)
Hello Hamish,
Are you currently using any NI Hardware? I see that you selected Generators  as the product type but didn't mention anything about the hardware you are using. I await your response to better help you with what you need to implement.
Ayman K
(10,495 Views)
Hi Ayman
No i am not using any NI hardware, im using two soundblaster cards for I/O.
To clarify my question, im wanting to generate the noise in software and output it using the sound card.
cheers
Hamish
(10,487 Views)
Hi Hamish,
LabVIEW does not have a built-in function that would create a noise signal given the PSD profile. However I would encourage you to take a look at the Signal Processing palette so you may be able to code the functionality yourself. Also I found this link that you may find useful.
Ankita
(10,457 Views)
Hi Hamish. I have the same problem. I need to produce a random noise that outputs a signal that conforms to a predefined PSD profile. I need to generate the signal.
I would like to know wether or not you could solve your problem.
(8,017 Views)
