Signal Generators
I wish to maintain the 'sampling frequency to signal frequency ratio' a constant.
I want to generate sine waves of varying frequencies, say, from 1 Hz to 1 kHz. Sometimes, a frequency swept sine wave. The problem is I wish to maintain the 'sampling frequency to signal frequency ratio' a constant. That means, the sampling frequency should be 20 or 30 times the signal frequency. This has to be done automatically. For example,  for a sweep of 1-10 Hz, if the desired sampling frequency is 30 Hz at the beginning, it should be automatically updated to 300 Hz as the signal frequency reaches 100 Hz. Can some one suggest a possible solution ?
(7,051 Views)
What hardware? What software? What have you tried?
(7,046 Views)
Thanks for the queries. I am using daq card USB-6221 and Labview. Used analog out put  with function generator, sine wave and sine pattern VI. I am successful to generate sine waves using the 6221 card, which will trigger an electro-optic modulator.
But the problem is that sampling frequency remains fixed throughout the entire band width.
I am not an experienced labview programmer.
(7,032 Views)
I would suggest you look at the LabVIEW examples. Example finder>>Hardware Input and Output>>DAQmx>>Voltage>>Cont Gen Voltage Wfm-Int Clk-Variable Rate.vi.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(7,025 Views)
Accepted by kumban
The Basic Function Generator function has an input called 'sampling info'. This is a cluster and one of the elements is number of samples. You simply have to set this based on your frequency.
I would strongly suggest you take the LabVIEW 101 course.
(7,006 Views)
Thank you Knutson. The scheme works excellent !
(6,958 Views)
