Signal Generators
I wish to maintain the 'sampling frequency to signal frequency ratio' a constant.
I want to generate sine waves of varying frequencies, say, from 1 Hz to 1 kHz. Sometimes, a frequency swept sine wave. The problem is I wish to maintain the 'sampling frequency to signal frequency ratio' a constant. That means, the sampling frequency should be 20 or 30 times the signal frequency. This has to be done automatically. For example,  for a sweep of 1-10 Hz, if the desired sampling frequency is 30 Hz at the beginning, it should be automatically updated to 300 Hz as the signal frequency reaches 100 Hz. Can some one suggest a possible solution ?
(7,052 Views)
What hardware? What software? What have you tried?
(7,047 Views)
Thanks for the queries. I am using daq card USB-6221 and Labview. Used analog out put  with function generator, sine wave and sine pattern VI. I am successful to generate sine waves using the 6221 card, which will trigger an electro-optic modulator.
But the problem is that sampling frequency remains fixed throughout the entire band width.
I am not an experienced labview programmer.
(7,033 Views)
I would suggest you look at the LabVIEW examples. Example finder>>Hardware Input and Output>>DAQmx>>Voltage>>Cont Gen Voltage Wfm-Int Clk-Variable Rate.vi.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(7,026 Views)
Accepted by topic author kumban
The Basic Function Generator function has an input called 'sampling info'. This is a cluster and one of the elements is number of samples. You simply have to set this based on your frequency.
I would strongly suggest you take the LabVIEW 101 course.
(7,007 Views)
Thank you Knutson. The scheme works excellent !
(6,959 Views)
