Signal Generators
NI USB-6218
Hello!
I am doing some measurement using NI USB-6218 with a simple inverting opamp configuration. I am having a problem with the phase shift/ delay between the input voltage and the measuremed voltage. I only take a voltage measurement at the output side. The input voltage is generated inside the NI USB-6218 board. How can remove this delay.
thanks alot
B.
Message 1 of 1
(6,329 Views)
