Signal Generators
Signal generator with peak output power of 1 kW
Is it possible to build a 13.56 MHz signal generator of the following specifications using NI signal generators, specifically PXI-5650?
Frequency = 13.56 MHz
Frequency stability = +/- 3 ppm
Peak output power = 1 kW
Duty cycle = up to 20%
Pulse width = 100 us
Ouput power selection = 1 dB step (from 100W to 1 kW)
Athough I design measurement and controls systems for biological applications using microcontrollers and related electronics, I'm brand new to this RF stuff. I have some exposure to LabVIEW.
So will this be something out of my league, or would this be doable with support from NI and a few weeks of self-study?
Mohit.
(5,823 Views)
There are many RF power amp manufacturers . If the freq is fixed I would go with a fix freq power source (13.56MHz is quite common) and just control/monitor the output with LabVIEW.
Greetings from Germany
Henrik
LV since v3.1
(5,799 Views)
