Signal Generators
NI USB 6251 - Signal Express - Input Ports display idential signals
I connected a DET50B (phototedector) to the Ai0 input port in my NI USB-6251 and through LabView SingalExpress 3.0.0 took a look at the signals from the Ai0 and Ai1 by clicking on the following:
Acquire Signal -> DAQmx Acquire -> Analog Input -> Voltage
I was expecting the Ai1 signal to be at 0 Volts, because there is nothing connected to it, and the Ai0 signal to vary with respect to the light I was shinning on the photodetector. Instead, both Ai0 and Ai1 amplitudes were identical and corresponded to the light I was shinning.
Why is it that these ports seem to be connected? The same thing happened when I opened the other ports for viewing through SignalExpress except the Ai8; this one seemed to be at zero (probably because it does not physically exist on the NI USB 6251 which has Ai0-Ai7).
Message Edited by AlfredoT on 09-30-2009 02:01 PM
Alfredo
(6,428 Views)
Accepted by topic author AlfredoT
No, you will not read 0 volts from an unconnected channel. Do a search for 'ghosting' for a detailed explanation. If you want 0 voltas on a channel, you need to gnd it.
p.s. You do not have a Signal Generator board. New questions should be posted to the Multifunction DAQ or Signal Express boards
(6,415 Views)
