Signal Generators
PCI-6703 - Problems with several cards?
I have to equip a PC with 48 analog outputs.
So I'm thinking about buying 3 PCI-6703-cards.
My question is, if there are any problems using several cards, are there changes in the update rate compared to the use of a single card?
(5,823 Views)
Hi MerkM,
that's right the PCI bus capacity is splitted up between the different PCI cards.
To avoid this splitting, you could use a card with PXI Express bus (PXIe)!
some additional informations:
Update Rate of the NI-6703/6704 Analog Output Devices: http://digital.ni.com/public.nsf/allkb/D2DB74A88332E5988625743B0062DDFC?OpenDocument
I hope this helps!
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(5,809 Views)
