Signal Generators
How to use PFI 0 as input/output trigger?
I am using a PXI-5412 as my signal generator. Using the generator, I was able to generate signal from CH0. However, I need to get a signal from another function generator as input to the PFI 0 to trigger the signal. Is there any example that I can use to figure it out? Thanks
Chandler
(6,575 Views)
You can try FGEN Trigger VI under the NI-FGEN examples for LabVIEW.
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(6,561 Views)
