Signal Generators
high frequency current generator
Hello, I am trying to find a function/signal generator that can output high frequency and high current. The frequency range should be 0-100MHz and the current should be 0-5A. I have looked at the function/signal generators here but they are all low current. Other signal generators from tektronix, rhode&schwarz, and agilent are also low current (<300mA). I'm trying to use it to generate high frequency magnetic field with a Helmholtz coil. Are there companies out there that make a high frequency high current signal generator? Thank you, Max
Message 1 of 1
(6,206 Views)
