Signal Generators
PCI 6723 - Sine wave generation
I am looking for an example for PCI6723 using Labview 7.1.  I would like to use three channels to generate sine waves.  I need to have the ability to change the phase for each signal.
--Lisa
Message Edited by lisan on 01-08-2009 05:46 PM
(7,422 Views)
I am looking for an example for NI 6723 using Labview 7.1.  I would like to use three channels to generate sine waves.  I need to have the ability to change the phase for each signal.
--Lisa
Message Edited by lisan on 01-09-2009 03:53 PM
(7,394 Views)
Try Help>Find Examples and then Hardware Input & Output>DAQmx>Analog Generation.
p.s. You don't have one of the NI signal generators.
(7,381 Views)
Hello Lisa,
If you are new to LabVIEW I would suggest you watching this video tutorial . This video presentation demonstrates some of the fundamental building blocks of a DAQmx analog output program in LabVIEW. The video shows how to create a simple VI that will write a sinewave to an analog output channel.
Juan Galindo
(7,371 Views)
