Signal Generators
Sine Wave generation for Spartan 3E FPGA
Hello, I am trying to generate a 44.1kHz Sine wave out of an I/O port which is located on my Spartan 3E starter board. I cannot get the ADC vi to work--for some reason, it will never build because my FPGA does not support Wire Array's (according to LabView's debugging output). Any help is appreciated, especially an example. Thanks in advance,
Obnauticus
(7,348 Views)
Hi Obnauticus,
As you are essentially using LabVIEW FPGA to program the Spartan 3E hardware, you will use the programming practices for the same. The first thing I would suggest is looking through this tutorial for best programming practices using the Spartan 3E. What is the source of your sinewave--is it an AO channel or software? Also explain what you mean by the ADC VI.
Ipshita C.
(7,322 Views)
