Signal Generators
Problem with sine wave on niFgen PCI 5411
Hallo all,
I'm using the niFgen PCI-5411. I want to generate a sine wave and a DC signal using the AWG. For both signals, they have to be generated with a frequency(f) and for a certain amount of time(t). If I am not mistaken, the loops for the signals to be generated is calculated by: frequency x time. Am I right?
For this task, I am using Create Binary Waveform and Arbitrary Sequence mode.
However, the generated sine wave looks strange because the negative portion of the sine waves are 'dissected' into 'small wavelets'. Can someone please explain why this is so??
Thanks alot.
Kind regards,
rainbow27
Message 1 of 1
(6,274 Views)
