02-11-2008 12:27 AM
02-11-2008 02:31 PM
I believe the example you are looking for is the RFSG Single Tone Generation.vi example. This example can be found by going to Start>>National Instruments>>NI-RFSG>>Examples then selecting the appropriate development environment. I hope this helps!!
02-12-2008 06:14 AM
Thanks for ur reply
yes correct i m looking single tone generation but i cant find any example option in NI RFSG menu.
can i use RFSG FM generate.vi with 0Khz deviation without message signal.
02-13-2008 10:59 AM - edited 02-13-2008 11:01 AM
I am unsure as to why you do not see the examples in your menu; I would suggest reinstalling the driver and verifying that the examples are installed with your driver. I have provided a screen shot of the block diagram of the example program if you wish to build this VI yourself (the false case is wired straight through).  I also do not believe you will be able to set the parameters to 0 on the RFSG Generate FM.vi I have tried this and receive an error.
02-18-2008 12:33 AM
