Signal Generators
RFSG & RFSA
Hello! I use a simulation NI RF Vector Signal Generator (ni 5673) and simulation NI RF Vector Signal Analyzer  (ni5665). How to connect rf output simulated generator  and rf input  simulated analyzer? Or how can I see the signal, generated simulated generator, use my simulated signal analyzer?
(7,171 Views)
Accepted by leomdma
Hi leomdma,
Thanks for posting to the forums! It is not possible to connect a simulated RF Out to a simulated RF In. I assume that you are asking this because you want to get a headstart on your development before the hardware arrives, unfortunately, you will not be able to validate the signal that you are generating until you receive the actual hardware. Please let me know if you have any more questions!
Kevin S
(7,157 Views)
Hello! The NI 5673/5673E)devices allows change properties or attributes during the Generation state. Are there examples?
(6,892 Views)
and how work configuration list?I want create signals generator, which will be generate the same signal with different delays. Delays less then 1 ms.
thanks
(6,889 Views)
Hi leomdma,
Look at the NI shipping examples? You can find them at <LabVIEW>\examples\instr\niRFSG or in the NI Example Finder by navingating to Hardware Input and Output > Modular Instruments > NI-RFSG (RF Signal Generator) > Configuration List > ...
If you need more help from there, post on the discussion forum board that actually supports NI RF products. You can find it here: http://forums.ni.com/t5/RF-Measurement-Devices/bd-p/290
Jason L
Product Support Engineer
(6,878 Views)
