Signal Generators
SRS 844 lock in amplifier and DS 345 function generator
Hello all
I'm a new Labview user and need help. I want to write a labview program for a resonant ultrasound spectroscopy system. I need to connect SRS DS 845 (func generator) and SRS 844(lock in amp) to each other, DS845 to PC and SRS844 to pc all at the same time. I want to generate signals from the function generator and read the resonance responses from the lock in. But i have no experience with labview programming at all.
isthere someone who might help me on this one??
thanks a lot!
Message Edited by gun on 08-22-2008 12:51 PM
(8,276 Views)
You can download an 844 driver and a DS345 driver and install them in you instr.lib folder. For information on what a LabVIEW instrument driver is and how to use one, see the 'Learn' section on the main page of the Instrument Driver Network. To learn some of the basics of LabVIEW, check the On-Line Training resources. You will also need a GPIB controller.
p.s. This board is for questions about NI signal generators. In the future, post to the Instrument Control board for related questions.
Message Edited by Dennis Knutson on 08-24-2008 07:19 AM
(8,263 Views)
if you want all in one, have a look at http://www.zhinst.com/products/hf2li
(7,442 Views)
