Signal Generators
Switchable sweep signal
Hi all,
I am still having trouble trying to simulate a signal that has 3 switchable sweeps. The frequency range is 8-800Hz. The sweep ranges are:
i. from 800Hz to 1000Hz, rising at the rate of 7% of 800Hz per second up to maximum frequency
ii. from 800Hz to 1000Hz, rising at the rate of 9% of 800Hz per second up to maximum frequency
iii. from 800Hz to 1000Hz, rising at the rate of 11% of 800Hz per second up to maximum frequency
Thanks.
(6,259 Views)
Hi maxidivine,
Thank you for using the National Instruments forum. I have noticed you have published the same question multiple times. Please use one forum thread. For this, can we keep everything within the forum - http://forums.ni.com/ni/board/message?board.id=170&message.id=421097
Kind regards,
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(6,230 Views)
Noted. Thanks a lot.
(6,226 Views)
