Signal Generators
Sending generated signals to a remote computer in a network
Hi guys, I am new to Labview and need some help. I use Labview to generate a modulated voice signal and i want to send this signal to a remote computer (real time). How can i do this, so that this voice signal is regenerated in the remote computer?
(7,481 Views)
Lots of different options. Are the computers on the same network? Then you could use TCP/IP, a shared variable, datasokets, etc. Look at some of the examples that come with LabVIEW. The Data Server/Data Client examples would be one that should give you some good ideas.
(7,479 Views)
Thanks Dennis...I saw that example and am working on it.
Warm regards and Merry Christmas.
(7,474 Views)
You can mark the post as a solution
Shreyas Hebbare
Shreyas Technologies
India
(7,452 Views)
Accepted by rocky3015
Hi Shreyas, thanks for the advice.
(7,442 Views)
Your thank you is not the solution.
You can undo what you did by clicking on 'Options' above the message body.
(7,438 Views)
