Signal Generators
Two timed sine waveforms in a single plot
Hello
I have attached my VI, and I need help with plotting the waveform.
Each symbol ( 0 or 1) have different frequencies. I would like to plot each signal one after the other.(like a FSK waveform)
I am trying to build my own FSK.
So far each signal is display one then the other.
Smiley Happy
(6,428 Views)
Accepted by ratatouille
Hit Ratatouille,
               To have the graphs display one signal after another, right click the graph on the front panel and replace it with a waveform chart. I think this solves the issue to which you referred. The functional difference between a waveform graph and a waveform chart is the way the X-axis is handled. For the chart, the x axis is real time while for the graph the x values are an input. In your case, the sine generation makes sine waves, but each generation has the same X values, so the best you could do would be to have them overlap.
Hope this helps,
Luke W
(6,416 Views)
thank you for your answer. I  have changed the waveform to a chart one. and it works good
thanks again
Smiley Wink
(6,408 Views)
