Signal Generators
Voltage and time waveform for the 33120A
I am having difficulty creating a arbitrary waveform that is a continuous voltage for X amount of time then shifts to another voltage for x amount of time. I'm trying to send this from labview 8.5 with a GPIB-PCI to an 33120A and have the 33120A output this. I would like to be able to change the voltage more than a few times and be able to set the time differently for each voltage change.
IE. 5V for 5 seconds then go to 3V for 7 seconds, or in even time intervals like 1 second each. Where Y axis is voltage and X axis is time.
Message Edited by camkat on 03-13-2009 03:22 PM
Message Edited by camkat on 03-13-2009 03:24 PM
(6,294 Views)
Dear camkat,
What kind of difficulty are you having?
Are you getting a particular error?
Did you use an example program from LabVIEW?
Sammy Z.
(6,264 Views)
