Signal Generators
daq 6133 signal generation
Using BNC 2110 and DAQ board 6133, can I generate a sine signal and output the sine signal?
(6,042 Views)
Accepted by WG_23
Hi WG_23,
Are you wondering if you can use your 6133 to generate a sine wave and then connect it to the BNC 2110 to connect it to something else? The 6133 doesn't have Analog Output capabilities, so you will need to use a different card to do this.
Best,
(6,036 Views)
