Signal Generators
frequency list on 5404
I want to load my PXI5404 with a frequency list, but the error message is:
Error -1074135024 at Ni Fgen Configure Output Mode.vi Occured
Possible reasons: Driver Status: (Hex 0xBFFA0010) Invalid value for parameter or property.
Invalid Output Mode - Supports only NIFGEN_VAL_OUTPUT_FUNC
Is it sure that the PXI5404 works with the Frequency list?
Tim
Message 1 of 8
(8,730 Views)
The PXI-5404 sine generator has no onboard memory to store frequency lists. Thus if you want to do e. g. sweep operations with this device you will have to use a software timed approach as it is used in the niFgen examples (e. g. niFgen_5404_Frequency_Sweep_Example.vi).
Frequency lists and arbitrary sequences are supported by Arbitrary Wafeform Generators like the PXI-5412.
Jochen Klier
National Instruments Germany
Message 2 of 8
(8,712 Views)
Thanks for the answer.
Unfortunately, the PXI 5412 has only 20 MHz bandwidth, so I need the PXI5404 with 100 MHz. Isn't it possible to store the data elsewhere? Or is it possible to give the frequency via the ref in port?
Tim
Message 3 of 8
(8,708 Views)
From the NI Signal Generators Help:
The REF IN connector is a PLL input connector that can accept a reference clock from an external source and frequency lock the NI 5404 internal clock to this external clock. The reference clock can be 3 MHz to 20 MHz in 1 MHz steps.
The frequency at the REF IN connector doesn't have a direct impact on the output frequency of the board. It is only used to synchronize the internal clock of the board with e. g. a extremely accurate external clock signal.
Could you please explain a bit more in detail what you attempt to do? Is the timing accuracy provided by software timing insufficient for your application?
Jochen
Message 4 of 8
(8,702 Views)
Thanks for the fast answer,
I have in my PXI System 4 Cards: 1 Multifunction Card (PXI 6259), 1 Analog out (PXI6723), 1 timing card (PXI 6602) and the PXI 5404 Signal generator.
When I start my program, I read all the data in the Mutlifunction card and in the AO Card as waveforms. The timing card is the master clock. The problem is, that I need very high timing accuracy (down to 10 microseconds or even less). And during one sequence of my program, I want to switch the frequency of the PXI 5404 card.
Adittionaly, I've attached my vi. The part for controlling the frequncy is under construction.
Tim
Message 5 of 8
(8,700 Views)
Just to clarify, Frequency List Mode is not supported by the NI 5412.
Only DDS-based generators support Frequency List Mode. That would be the NI 5411, NI 5431, NI 5401.
Marcos Kirsch
Staff Software Engineer
Signal Generators Group
Marcos Kirsch
Chief Software Engineer
NI Driver Software
Message 6 of 8
(8,682 Views)
I believe this exact question was answered in this thread:
http://forums.ni.com/ni/board/message?board.id=310&message.id=484&jump=true
To refresh: set up a digital trigger on the 5404.  Update the frequency in software- it will not take affect until you send another trigger.  This is how you can upate the 5404 frequency in a hardware-timed way.
Message 7 of 8
(8,668 Views)
I'm trying to do exactly this, but it isn't possible to update the frequency data so fast like I want to switch it. I need frequency steps with a duration of 1 ms...
Here's my vi where I tried to realize this
Message 8 of 8
(8,663 Views)
