Signal Generators
op-amp as a Integrator
Dear sir,
 I have one doubt in op-amp as a integrator. How the sine wave is converted to cos wave, please explain the working and give me the analysis of the integrator.
Thank you,
regards,
vinoth kumar.D
(8,666 Views)
Hi Vinoth,
Are you using any specific piece of hardware or is this more of a theoretical question not related to National Instruments products? Do you need a piece of hardware that will do this?
B Spears
(8,644 Views)
Hi Vinoth,
The role of integrator, just as simply as the word says, is to perform Integration. From the theory of calculus, we know that :
int (cos(t)) = sin (t)  + C.
int (sin(t)) = cos (t) + C.
where 'int'  =>   indefinite integral and C is just an arbitrary constant.
Hence, when the op-amp is acting as an integrator, if the input signal is a sine wave, the output signal is the integral of sine wave , which is, cosine wave.
Hope this helps,
Sastry
Sastry Vadlamani
RF Principal Software Engineer
Aerospace and Defence BU
Certified LabVIEW Architect
(8,633 Views)
Dear Sastry Vadlamani,
              First of all I would like to thank to you sir for giving me the explanation for the integrator circuit. But still I have a confusion with it if you could clear me this , i hope it will be helpfull. How the op-amp is integrationg the sine wave , please explain me with an example.
regards,
vinoth kumar.D
(8,630 Views)
Vinodh,
You will find innumerable resources on the web (Google) about the basic fundamentals of Op-Amps being used as integrators.
Below is the link that will help you go through different resources.
The Google Search Link
Sastry
Sastry Vadlamani
(8,617 Views)
