Signal Generators
square wave genearator
Hi All,
I just bought NI USB 6009 and now I need one simple signal generator (external clock +5vsignal) for my microcontroller (+ 1Mhz). Is it possible to use my usb6009 to do it, with programming in VB or VI?
(7,732 Views)
Please post this under Multifunction DAQ forum for better response. USB-6009 is Mult-function DAQ card.
Here is the link to Multifunction DAQ Card
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(7,722 Views)
Hi Chrs,
Your USB-6009 does have two analog output lines on it, and they can drive 0 - 5V.  However, it has a maximum update rate of 150S/s and thus will not be able to provide the 1MHz frequency you need.  I would suggest an M-Series DAQ device for your applications.
Nicholas B, National Instruments
(7,715 Views)
thank nicholas, i will consider it...
thx
chris
(7,668 Views)
