SignalExpress
Acquiring CONSECUTIVE signals with Signal Express
How can I record multiple signals consecutively in Signal Express using the same input device and the same DAQ channel?  It seems to me that even if I have separate execution loops, the program will still try to run all the acquisitions at the same time through the same channel.   ..and I'll get an error.  I've tried one exceution loop and I can't the program to do this ..even when I have the 'run after previous step' box checked.  Any help would be much appreciated.
(5,971 Views)
Hello Sound Tech
You do not have to put another step inorder to acquire multiple channel. In the first DAQmx Acquire step you can select multiple lines by pressing Ctrl and configure your timing and you will be all set.
nAyer
(5,959 Views)
