SignalExpress
Can I read TEDS from Signal Express?
Is there a way to read the TEDS information from within Signal Express?  The documenation doesn't even have the word TEDS listed in it anywhere.  I've found that I need to access the TEDS info via MAX first.  Then when I add a step to acquire an appropriate signal type then the task windows shows that I can access the TEDS info.  So I found that capability...
But if I change change channels, or transducers, I have to go back out to MAX to read it and start all over.  Is there no way in Signal Express to re-read the TEDS chip and update the channel view?
cDAQ-9171 with NI9219 module
SignalExpress 2013, V7.0.0
OS = Windows 7, 64 bit
(4,707 Views)
Usually with Signal Express what you see is what you get, there are not a lot of options for customization. You may get more options if you implement this in LabVIEW.
Michael Bilyk
Former NI Software Engineer (IT)
(4,684 Views)
