SignalExpress
Set up Signal Express to log when there is a change in state of the inputs (NI USB-6501 logger)
Hello NI Forum, I have recently purchased digital I/O logger NI USB-6501.  This arrived with Signal Express, which I intend to use as a Lite version.  I just wondered if it was possible to set up Signal Express to only add a log entry when there is a change in state of the inputs?  I have this working on a 0.1sec sample period and can interrogate the logs after recording.  Most of the time nothing will be happenning, I just wondered if there was a way to reduce the ammount of data captured?  Cheers.
(5,051 Views)
You can add start and stop conditions to the recording options
(5,031 Views)
Hi  Jimbo, thanks for the response.  My copy of Signal Express has now rolled back to the Limited edition.  I dont have a license for the full version.  I tried to find the 'Recording options' tab on the screen, but not sure where this is located, maybe this is not supported in the limited edition? I am logging all inputs at 100ms intervals for now.  Regards, Gary
(4,991 Views)
Ah that unfortunate, and yes start/stop conditions for loging are part of the Full version of SignalExpress 😞
Sorry about that
(4,987 Views)
