SignalExpress
Can I use Signal Express to control a Data Translation Card?
Hello.
We will buy a Data Translation card to my project. (DT9841 : http://www.datatranslation.com/products/dataacquisition/usb/dt9841.asp)
Then is anyone know if that's possible to control a DT card with Signal Express?
Thanks in advance.
PS: I'm french, then sorry if my english is not really good.
"Ainsi s'éteint la liberté, sous une pluie d'applaudissement." - Amidala
(7,050 Views)
Hi HOKUTO,
You can't control a a DT board with LV Signal Express.
But you can do it with LabVIEW, I saw there is a driver to use this board in LabVIEW.
It's possible to import a VI from LabVIEW to Signal Express but you must have LabVIEW.
Regards
VéroniqueD
NI France
(7,028 Views)
Ok. So I'll do it with Labview.
Thanks.
(7,024 Views)
Finally, I won't use Labview. Smiley Sad
The agent of Data Translation said that the DT9841 card is only compatible with LV-Link/RT-Streaming (2615$), not with the standart LV-Link (195$).
Thanks for your reply.
(7,013 Views)
