SignalExpress
Can signal express record for a long period of time?
Hi there,
I am trying to record using signal express over a period of time. However, whenever I do so I either get one of two error messages depending on the particular vlaues. I try to input ~300 seconds for time per record and I get an error message of "invalid input " to the time per record. Or if I put in ~100s it tells me to turn off certain functions, like data viewing whil elogging, and I do so but it still does not fix the problem.
I need to look at a voltage signal over a couple of minutes of time and it is not letting me do so.
I am getting the signal from a Tektronix oscilloscope and it will let me record for small amounts of time, but nothing large. I am using the IVI scope acquire step.
Please help.
-Keith
(6,113 Views)
What kind of Tek scope are you using? Is it possible to post screenshots of these errors? What are the 'shorter' periods of times that it works for? Can you find a cut off point of where it breaks?
Peter Flores
(6,094 Views)
