SignalExpress
Cannot manual set time scale in Data View - reverts to autoscale on run
There was a similar post from someone evaluation SignalExpress but they did not respond to follow-up questions.
I cannot set the (x-axis) time scale in the data view.  When I turn off  autoscale and manually enter a value, it appears to change, is presented correctly in the both the preview and the Data View pane, ONLY until I hit RUN, then it reverts to autoscale.
This is maddening.
The attached JPG shows this behavior.
(7,426 Views)
Accepted by wildcatherder
To solve this issue, you need to right-click on the graph in Data View.  Select X Scale»Deselect Autoscale.  Then, double-click on the lowest/highest value and change the value to be the low/high end value for desired viewing range.  Changing the scale in this manner should not revert to Autoscale during runtime.
Sara Lewandroski
Applications Engineer | National Instruments
(7,408 Views)
OK, that works.  Now WHY doesn't it work from the Properties dialog or what's the point of it being on the Properties dialog?  This is a BUG and should be reported and fixed.
(7,408 Views)
This problem was found internally and filed as CAR #221702.  It's current status is fixed pending for our next release.
(7,378 Views)
Good to know.  Thanks
(7,373 Views)
