SignalExpress
Channel or repeated capability name required
I'm new to LabView in general, though I have used it sparingly before. I am trying to output an arbitrary function through the Tektronix AFG3022. As you can see in the attached picture, I just have 2 sine waves and want to manipulate them. I get a configuration error, however, when I try to run this. Browsing through the forums, I see that this error may be a driver issue in other scenarios.. but I just installed SigExpress yesterday fresh from Tektronix' website, so any of the configuration setup was done through the install. I can use the Tektronix equipment to output Standard Functions, but it won't work (under the same circumstances) when I try to generate through SigExpress's Arbitrary Function block.
Any help would be appreciated. Thanks.
(7,008 Views)
crut,
Would it be possible for you to post a screenshot with the details of the configuration error visible?
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(6,987 Views)
