SignalExpress
Configuration of NI USB-4432
Hi, I'm using NI USB-4432 to measure the acceleration from Dytran, 3225F1 accelerometer using LabView SignalExpress 2009. I'm facing problem in setting up the Configuration. I know that the sensitivity is from accelerometer, but I  am not sure what settings to put in IEX Source, IEX Value, Terminal Configuration, dB Reference and coupling mode in the Device setup. Where should I look for this information?  What should I consider before I do any setting? Please advise. Thanks.
(6,404 Views)
(6,385 Views)
thank you very much
(6,379 Views)
