SignalExpress
Convert Milliamp to PSI
I am using signalexpress to read pressure through a pressure transmitter.  The transmitter is a 4 to 20 milliamp transmitter.  On my graph in signalexpress I want to convert/scale the milliamp to psi reading.  I am using the 9203 card.
(7,856 Views)
You have two options.  You can use a custom scale on your acquisition block (DAQmx Acquire), or you can use the Arithmetic block to scale the data after it is acquired.
(7,841 Views)
I'd recommend the function "Scaling and Conversion".
The unit can be changed under Custom Scaling before logging or under Properties for the graph after logging.
//Ingenjör Hansson
(7,826 Views)
Create a "Custom Scale"> Map Ranges> Scaled Units= PSI> Pre-Scaled Values Min/Max= 4/20> Scaled Values Min/Max= consult your datasheet but this will be the min/max range of the xducer at 4 and 20mA.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(7,822 Views)
