SignalExpress
Create 5 VDC power supply with SignalExpress, USB-6251, SC-2345, SCC-FT01?
Using SignalExpress, I haven't been able to configure an SCC-FT01, plugged into an SC-2345 analog output slot (J17), as a 5 VDC power supply for a 0.6 mA sensor.  Do I specify an offset of 5V in the Create Analog Signal step? Should I care about Sampling Conditions?  Do I specify the voltage in Value to Write of the DAQmx Generate Analog Output dialogue?  Is a constant 5VDC a 1 Sample Generation Mode or Continuous Samples?  Should I care about Update Periods?  Triggering?  Execution Control?
Running various combinations of the above variables, I have been unable to meter 5V over any combination of the SCC-FT01's terminals.
(5,957 Views)
Figured it out.  The SC-2345 had been remapped with the Measurement and Automation tool.  Reset to factory defaults and the analog output slot began outputing an analog signal.
(5,956 Views)
