SignalExpress
Data Capture Stops
All,
We're having an issue with a signal express setup where one of our captured signals stops acquiring data some time into the capture. We're capturing 5 4-20mA signals and one thermocouple signal. All of the hardware is setup to capture continuous data at 1 hz. We have a simple data view setup with waveform charts. At a consistent point after the start of the capture the thermocouple chart will stop updating and it doesn't appear as if we recieve any new thermocouple data.
Thanks for any help in advance.
Ken
(5,614 Views)
Ken,
If possible, could you post your code so we can have a better picture of what is happening? Is the amount of time that passes or data points acquired before the chart stops displaying consistent each time or does it vary with each execution of your code?
Allison M.
ni.com/support
(5,605 Views)
