SignalExpress
Data Logging Rate
I am a complete noobie and trying to record thermocouple data using Signal Express 2012.  I can get the data to record and export to a text file, but it is recording at 1.1 seconds.  I would like to change it to once every second, but don't see that option anywhere on the record options.  Thanks for any help!
Tom
(10,974 Views)
Accepted by tbsmith
Hi tbsmith,
So I think you are getting a little confused. The recording is not where you set these options. You want to set the 1 sample per second in the configuration under timing settings. This is where you set the timing of the aquired signal. In your case a thermocouple. I hope this helps.
Here is a screen shot of it.
Ryan
Applications Engineer
(10,962 Views)
@Ryan-AE wrote:
Hi tbsmith,
Thanks Ryan.  There was no screen shot.  Anyway, I had posted this on a different (wrong) forum and someone else answered it so I guess I'll close this one.  If you could post the screen shot though, that would help.  thanks!
(10,960 Views)
Sorry my mistake
Ryan
(10,955 Views)
I'm also looking to do this but I don't see a timing settings. I am using the 30 day trial currently. Is changing the data logging frequency not possible with the trial version?
(6,755 Views)
(6,747 Views)
This thread shows a different device. I'm using a Tektronic DPO 4104, which doesn't have the same device logging options.
(6,739 Views)
